Software Settings changes
jjuk
Can we get "Geometry 6° (tuning)" moved to the "Limits" tab, below cyclic ring?
It's a essential required step of the setup and therefore should not really be an advanced setting.
I think maybe "auto-rotation bailout time" should be moved to the Governor settings tab.
thank you for your message.
Geometry 6° is in the Advanced tab, because once you will set it with the Setup Wizard you should really not change it. Only in cases when you know what you are doing a changes are needed. For this reason it is just for those that know implications of changing it.
Also the parameter is not considered as a Limit.
jjuk
I change it every time i crash and break servo arms as the servo arm position and link lengths change each time.
