Spirit red gov + geolink + HW v4 telem + SBUS + FrSKY Telem
jjuk
Is it possible to have the following configuration with a standard red spirit?
Spirit Red with Spirit Governor
Geolink
HW v4 telemetry (for current measurement)
FrSky R-XSR via SBUS receiver
FrSky telemetry for Taranis integration and current consumption readout.
I'd like my taranis to give me a callout when i've used 1000mah, 1100mah, 1200mah etc, so need to use HW v4 current sensing and frsky s.port telem to pass the current usage to the taranis.
Using flight timers should be well in the past now.
unfortunately this is not possible with Spirit unit. You can't connect GeoLink and HW telemetry cable at the same connector.
With Spirit Pro it is possible since it has two Spektrum connectors.
