Futaba gv-1 governor senser
leatherface
Hi, does the GV-1 sensor work with spirit? And also via satellite port or normal connection? Thankyou.
yes, it is working. Powering lead should be connected to a BEC, so not the Spektrum connector.
But since it is important to set a proper distance from the backplate we recommend to use a Hall sensor such as one from Align, BeastX or Spartan that is sensing magnets.
leatherface
ok,thankyou.it came with a second hand n7.i have an align governor sensor,i will use that.
