Spirit Telemetrie
gerry
Hello Tomas!
Me and a few colleagues would have a very big request to you.
At the moment Kontronik Kosmik sends the telemetry data to the Spirit Pro via the cable, the Spirit forwards the data individually to the receiver (Jeti). The individual parameters also have a name with S RPM or S Capacity etc.
In normal operation with the Jeti telemetry it works well too.
Together we wrote a nice LUA app for displaying our telemetry. The app recognizes all common multisensors.z.Bsp.Unisence, JLog2.6, Mezon and GPS sensors, etc.
Unfortunately, the Spirit outputs the sensors individually to the receiver, so they are not recognized by our app. If we hang a JLog between the Kosmik and the receiver, without dragging over the Spirit, then it works perfectly, because the JLog is recognized by its name as a multi-sensor from Jeti.
But we want to use the Spirit as a transmitter of telemetry and do not use a JLog.
It would be very important to us if you could solve this problem, that is to bring the spirit that it announces itself with its name "Spirit" as a multi-sensor at the receiver and the transmitter then checks which sensors the Spirit has available.
Knowing and using you, your work and the Spirit since the beginning, I know you can solve this problem.
Please help us.
Greetings Gernot
Greetings Gernot
sadly there is nothing we can do in our side. This must be implemented in the Jeti radio firmware.
We will send request to Jeti.
