Spektrum sats
ritchieicu
Hi
I recently setup the geolink using 2 sats, i dont have the pro so purchased the adaptor from you.
Everything has been fine up until today, i lost complete control and the heli smashed to bits. after checking i realised that one of the sats wasnt lit and then realised the ground wire had snapped off.
Why didn't the second sat take care of things? its lit up showing it bound but as soon as i disconnect the main sat i lose all control
TIA Ritchie
Sent from my ONEPLUS A5010 using Tapatalk
that is very sad. Normally it should switch to other sat immediately in a few miliseconds.
If I understand it correctly were you able to replace the cable and verify that the satellites are not switching, am I right?
If so then is the Spektrum Multi Adapter connected according the following photo?
http://manual.spirit-system.com/index.p ... ti_Adapter
ritchieicu
Whoooops i had it on ele and not ail! all working now. I neded a rebuild as i haven't crashed in a few years due to the spirit bailout, although it was a pretty major one :-)
