Kontronik Jive 80+HV Telemetri not working
karlmort
Hi.
I Can not get the telemetri to work on my spirit and kontronik jive80+HV(and Jive120+HV)
My sett up is:
Spirit(black)
Frsky X4R
Sbus converter
Frsky telemetri wire.
Telem UNI cable, with changed wire around(Red-Orange-Brown)
Kontronik jive80+HV and jive120+HV(Only one at the time of course)
Spirit send the all the telemetri values back from spirit, but the value from the kontronik is all showing 0.
I suspect that the firmware in the jives are to old to work ?
I have the send them inn to get them updated.
Best regards
Karl Morten
please make sure that the Telemetry in the Spirit Settings is configured to Jive Telemetry. This si very important.
karlmort
Hello.
Thank you for your reply.
Its working now :)
The actual problem was that the kontronik did not arm during my testing.
And the Kontronik is apparently not sending any telemetri data before its armed.
So now all the values are showed in my Frsky Horus.
Best regards
Karl Morten
Rufus
^^^^ Lucky you and good its working,cant seem to get mine to work.
Sent from my SM-N950W using Tapatalk
Indeed, it must be always armed otherwise telemetry is not sent. But flying without armed ESC is not possible in any way :)
Rufus
ZeXx86 wrote:Indeed, it must be always armed otherwise telemetry is not sent. But flying without armed ESC is not possible in any way :)
Tomas,I did set mine up,the ESC does arm but I'm not getting any readings or see the integration.My post is above this one.
Any suggestions ?
Thanks.
