Computer/Mobile device cannot detect Spirit Wifi-Link
Cempo
Hello!
I have a ca. 2 year old wifi-Link, long not used.
When I tried to activate it again with my spirit flashed with newest aerosoftware I couldn´t connet it to my Computer/MobileDevice - The wifi ist not detected.
When I used it 2 years ago with helisoftware it worked without problems.
Can sombody please give a hint what to do?
Thx in forward for responses!
Cempo
you have to update the Wifi-Link for the latest Wifi-Link Aero firmware. You can download Updater from our web page.
Then it will work again.
Cempo
Hi!
Thank You for the reply!
But I couldn´t solve the problem.
I installed the updater and got this errormessage after the start:
Module with IP 192.168.4.1 was not found
And there is no wifi to choose in the wifi-list, which is other then the "normal" ones of my neighbours.
By the way, I have Windows 10 running.
The wifi-link itself does "blue blinking".
Greetings,
Cempo
it depends on what you have configured previously in the Wifi-Link.
Maybe the module was switched to the Client mode only. In this mode you will not see a Wifi-Link network.
But if it was connected to your home network, then you can access it through assigned IP address from your network from any computer.
So then you can enter the IP address also in the Updater.
If you are not technically skilled in this area I can help you more. Do you remember if you have configured your home network in the module?
Cempo
Hello!
I only used it with android-mobile devices.
...and unfortunately I'm not skilled in technical computerstuff.
further support would be great!
greetings, cempo
