Bind Plug for dsmx sat and uSpirit
Tgilf
What kind of bind plug is needed here?
The nano lite one from spektrum with the jst connector which connects two pins side by side on the uSpirit or the normal spektrum one via link cable which seems to connect the outer two pins.
it is enough to use Spektrum bind plug with our JST-Servo adapter. The adapter is provided with the uSpirit package. So you should already have everything needed.
Tgilf
ZeXx86 wrote:Hello,
Thanks!
