Geolink, bailout, return home.
ritchieicu
I have been using spirit with bailout since the very early days of the unit and so very comfortable with the bailout, its in muscle memory. Return home is currently on a separate channel and switch, I would like to use the return home along with bailout but i assume this isn't possible as the heli would continue to climb all the time the stabi/bailout switch is activated.
Any advice would be appreciated.
Ritchie
Sent from my ONEPLUS A5010 using Tapatalk
you are right, but what behavior you are expecting actually?
Usage at the same time is possible.
ritchieicu
I want to bailout when im in trouble and disorientated return the heli home without it continuing to climb.
jjuk
I'd like the same, or just climb to 50ft and hover (position hold) until i'm ready to continue.
