[SOLVED] Heading Lock Travel Adjustment Question
sawacs
How do I set the control travel when in heading lock mode?
For example, when I am in rate mode I have the travel setup for say 60% travel. However, if I change the gyro gain in the transmitter to engage heading lock mode, my control rate appear to be at 100% during full rudder stick deflection.
Is this an adjustment I need to tune in the TX such as endpoints?
this is very normal and correct behavior.
Travel Adjustment is done just single time in the Rudder end-points limit settings.
sawacs
Thank you!
