Prevent motor spool-up when connected to USB/Bluetooth/Wifi
Posted: Wed 24. Apr 2019 16:27:58
by jjuk
The motor only needs to spool-up when configuring the governor, so a tick box in the governor setup screen to enable the motor would be good to stop accidental spool-ups. The motor will turn off when governor setup screen is exited.
In all other screens, the motor will ALWAYS be disabled, regardless of throttle setting on the Tx.
Re: Prevent motor spool-up when connected to USB/Bluetooth/W
Posted: Thu 25. Apr 2019 8:07:06
by Shonkonray
Then you wouldnt be able to use the vibration analysis!
Posted: Thu 25. Apr 2019 9:51:34
by jjuk
Shonkonray wrote:Then you wouldnt be able to use the vibration analysis!
Ah yes, forgot about that. Enable the motor for that test too. But everything else should be disabled.
