Geolink randomly connecting and disconnecting
tdeane
I have one of the original spirit Flybarless gyros from November 2014, I have it in an Align TREX500 and have just added a Geolink to the setup. I have everything configured but I keep getting the Geolink disconnecting and reconnecting virtually continuously every few seconds. When connected by Bluetooth I see at the bottom of the Geolink screen the following message when I press the Geolink Module option. "Connection with the Geolink is unstable" The Geolink has been calibrated and I have checked my configuration, all seems to be okay. The blue light on the unit stays solid throughout once it has acquired the satellites. There is no indication in the logs of any problem with the geolink.
Please advise me of how to proceed to get this working properly, I do not want to fly it when there obviously is a problem with the connection
ritchieicu
tdeane wrote:Hi,
I have one of the original spirit Flybarless gyros from November 2014, I have it in an Align TREX500 and have just added a Geolink to the setup. I have everything configured but I keep getting the Geolink disconnecting and reconnecting virtually continuously every few seconds. On the hone connected by Bluetooth I see at the bottom of the Geolink screen the following message when I press the Geolink Module option. "Connection with the Geolink is unstable" The Geolink has been calibrated and I have checked my configuration, all seems to be okay. The blue light on the unit stays solid throughout once it has acquired the satellites. There is no indication in the logs of any problem with the geolink.
I get a similar thing even when using the usb lead
Sent from my ONEPLUS A5010 using Tapatalk
LogoX2
tdeane wrote:Hi,
Verify you have Firmware 2.6.1 in the Spirit and 1.0.2 in the Geo Link.
tdeane
Thanks, yes I updated the firmware on both yesterday and the results are the same.
Sent from my Pixel 3 using Tapatalk
You are talking about Bluetooth module, is the issue present also with USB interface?
ritchieicu
ZeXx86 wrote:You are talking about Bluetooth module, is the issue present also with USB interface?
Yes i have the issue with the usb interface, only when i go into the geolink tab, i normally just reboot the spirit a couple of times, i didn't take much notice until i saw this post. I have a new grey unit.
tdeane
Yes it also happens with the USB interface.
tdeane
[quote="tdeane"]Yes it also happens with the USB interface.
Here is a link to a video of the USB link connecting and disconnecting, I apologise for the focus issues.
https://photos.app.goo.gl/B2Eo3BDjcaB4i6xm8
tdeane
Can I please get some advice on how to get this resolved?
Yes, I will send you private message.
