[SOLVED] HW120a v4 10 second delay til blades start rotating
Posted: Mon 06. May 2019 16:02:47
by Tfmcnellis
I have the HW 120 v4 Esc configured to fixed wing. When I engage the TH it takes 10-12 seconds until the blades begin to rotate. Any suggestions?
Re: Hobbywing 120a v4 10 second delay til blades start to ro
Posted: Tue 07. May 2019 6:40:32
by Shonkonray
If you have calibrated your endpoints (throttle range) correct and the problem still remains i would suggest that you increase the "spoolup rampup".
Please see the attached quote from the manual:
"Fine-Tuning – Spoolup Rampup
Value that will be added at the beginning of motor spoolup – when Hold is turned off. If the spoolup is not smooth, i.e. motor will start with a kick, the value is too high. If the spoolup has a delay, the value is too low. Default value of 50 μs should work fine in the most cases."
Posted: Tue 07. May 2019 14:00:27
There are two possibilities:
1. You have enabled two Governor - one in the ESC and second in the Spirit unit.
2. Throttle Range is not calibrated with Spirit unit. When calibrating Governor in the unit must be disabled.
3. Throttle Range in the Spirit unit is not at default values.
Posted: Tue 07. May 2019 16:45:26
by Tfmcnellis
I recalibrated with the gov turned off and everything is good.
Thanks!
