Different Headspeeds / Governor
Tgilf
Hi!
I need you help again.
At the moment I am using the Hobbywing 25v4 esc and its internal governor with uspirit on the oxy 2.
How can I change Head Speeds? I have a switch assigned for bank switching. Is head Speed chaning possible to do with the switch without using Spirits Governor? Or should I use the spirits gov ?
TOm
I am not sure if I understand the question. But you can change Head speed as always. Spirit has no influence on the HobbyWing Governor.
Just change throttle curve in your radio. That is the way how you are changing headspeed. Same apply when Spirit Governor is used.
