Spirit on Goblin 570 Delphin in Forward
cc1975
Hello, i have Delphin Behaviour in Forward Flight.
Should i increase Cyclic Feed Forward from 4 to 6 to eliminate? Elevator Filter is on 4. Cyclic Gain is on 60. Flight Style is 5. RPM 1700 and 2100.
Greetings Christian
cc1975
Or should i reduce Cyclic Gain from 60 to 55?
you should reduce Elevator Filter to 2-3.
Possibly the problem could be in incorrect setup of the Geometry 6° parameter.
Is the problem occurring also when you are not moving with Collective Pitch at all?
Dolphin can be caused by a several factors:
a) Main blades are very aggressive and not optimal for FBL usage.
b) Cyclic Travel Range is limited in the software too much - increasing Aileron/Elevator Range in the Limits tab will help.
c) Servos are not mechanically configured properly - especially mechanical center could be off. In that case configuring it according this guide will solve all possible problems and imprecisions: http://manual.spirit-system.com/index.p ... tive_Pitch
