uSpirit wizard with only 4649T, no satellite
xoexoe
For Spektrum TX users, is it possible to go through the wizard setup on uSpirit with only a 4649T receiver instead of a satellite receiver? The only option it gives is a satellite. If I just go through the wizard process at step 4 pretending the 4649T is a satellite, I can get the receiver to bind but there is no control of the unit.
Find me on HeliFreak, username Xoexoe
Juan Cobo
Yes, I have an Oxy2 only with uSpirit and spm4649t, you have to select dsmx to bind it and then remove the BLIND from the spm4649t.
In other configurations I always test the satellites and spm4649t separately and it works fine.
