Graupner RX SUMD od SBUS?
shark25
Graupner system can SUMD and SBUS.
What would you recommend what I should use?
Actually, I would prefer SBUS.
Or do I have any disadvantages?
greeting
enied
I am using SUMD, this is the Graupner protocol and everything is working as it should. I did not even think about using SBUS on Graupner hardware, what should be the benefit ?
BR Eugen
Graupner has support only for SUMD or PPM. We recommend to use SUMD in any way.
shark25
"Graupner has support only for SUMD or PPM"
Sorry, but that's not right.
Graupner also supports SBUS!
But I have switched to SUMD and hope for good support in case of problems.
You are right, the latest firmware versions can work with SBUS.
But we recommend SUMD for Graupner.
