slow cyclic servo movement
jaffrie
Hi Guy,
Need some advice. Been awhile since I last did a new build. Completed set-up with Jeti Tx & Spirit Pro
on Sab Havok 280. During cyclic ring set up servos was moving pretty fast so everything work ok but
after completed set up & re power up the heli cyclic servos are moving at about half the speed. Guess
I must have miss something, would appreciate some help. Tx swash set to mechanical, Rx 3 connected via
Ex Bus on E2 .
Thanks in advance
jaffrie
Any one can advice ?
Thks
jaffrie
Problem discovered & solved
The behavior you are describing is very normal and everything is correct.
It should not move fast actually since it is not flybar. With no model response to a commands the behavior is just different than in the air.
It is important how it feels in the flight not on the bench. Depending on this you should make an adjustments.
