Moving a Geolink between the UK and Corfu (Greece)
buttles
One for Tomas really but here goes!
I'm taking my Logo to Corfu and was wordering if the fairly small Variation difference between the two would negate the need to swing (Calibrate) the Geolink. I only use return to home and alt limit.
Cheers
we recommend to perform Compass Calibration. For Return to Home it is required.
But you can always check how it will perform. It should be still useable but testing must be performed very carefully.
If precision will be bad then you have to perform calibration. Or at least you can use Compass Heading Correction parameter.
buttles
Thanks Tomas, back now. I didn't calibrate and it seemed to work Ok.
