Futaba throttle problem?
John tan
I am trying to get throttle to work on my Futaba 8J. Can't get throttle assigned no matter what channel I select in the software. What do I do next?
I connected my YEP Esc to the aux channel on the Spirit btw. Is this correct?
andy6409
unless you want to use the spirit governor just connect the esc straight to your RX throttle channel , that's what I did with my 10J
John tan
What about the rescue channel? How do you map it to your 10J
Can other Futaba owners share your methods too?
Please assign Channel 1 to Throttle function at the General / Channels window.
Then it should work.
