Gain setting in Transmitter; Tail oscillating
Posted: Fri 19. Jul 2019 10:49:09
I am using Spirit Pro and a JETI DS24 with a Diabolo 550.
QUESTION 1: I set both rudder gain and cyclic gain in the transmitter (under "Heli Tuning" | "Gyro Settings") and not in the UNIT (Spirit) itself. I use the Spirit function "P: Cyclic Gain". That is why because so I can use "Tuning" and set a little bit rudder and cyclic gain during flight (if wind changes). In other words: I do not set rudder and cyclic gain in "Device Explorer" (JETI Integration), but I set it in JETIs "Gyro Settings". My question: But in "Device Explorer" there is still a menu item called "Cyclic Gain" with 82% (!) and I can change this value. In my JETI there is a value of 55%. I am confused. Which value is the right one? Besides: There is no menu item "Rudder Gain" in "Device Explorer", only "Cyclic Gain".
QUESTION 2: I have problems with tail. It is oscillating from left to right, right to left, left to right etc. It is a slow oscillating. I would say in one second from middle to left and back to middle. Rudder gain is at 100%. Should I put ball link on the rudder servo arm closer to the center?
Kind regards
Chris
Kind regards
Chris
