[ Version 2.6.2 released! ]
New version 2.6.2 was released!
  • GeoLink Altitude Limit improvements:
    • Altitude is determined and calculated from multiple sensors to be more precise during demanding maneuvers.
  • GeoLink Return to Home and GeoFence update:
    • Programming through radio is allowed only when Spirit Settings is not running and the unit is not in the configuration mode.
    • Both features can be programmed differently for each Bank.
    • IMPORTANT: Please set Return to Home and GeoFence positions for Bank 1 and Bank 2 (if used).
    • FIX: μSpirit unit with certain Spektrum satellites were unable to correctly program new points through a radio.
  • GeoLink Return to Home update:
    • Swashplate indicates programming progress with Collective Pitch in the opposite way.
  • GeoLink Auto Landing update:
    • Descending speed can be configured individually.
    • Initial landing is sped up.
  • GeoLink Position Hold update:
    • Changing position by sticks is more convenient and predictable.
  • GeoLink Altitude Limit and Altitude Hold update:
    • Lift off altitude (zero) is taken at the time motor is not running.
  • GeoLink Altitude Hold update:
    • Maintaining altitude is more consistent.
  • GeoLink communication:
    • GeoLink communication stability was improved with a small Spirit units (Red and Black Edition).
  • Support for 16 channel Failsafe:
    • Failsafe can be configured for all 16 channels now.
  • Spektrum integration update:
    • FIX: Spektrum integration and telemetry were occasionally inactive when using Spektrum DX9 and multiple Spektrum satellites.
  • Spirit Settings software:
    • New Auto Save feature for saving changes to the unit instantly.
    • New Preset for LaHeli LA380 in the Setup Wizard.
GeoLink users: After update from version 2.6.1 configuration of the Return to Home position and/or Geo-Fence for Bank 1 and Bank 2 must be repeated.
Update for the Spirit units is available in our Download section.
