reduce shaking at low rpm goblin 570
cc1975
Hey,
i want to fly my Goblin 570 also with low RPM. If i fly with 2100 or 2600 RPM all ok, but if i go to 1800RPM or lower i have shaking on the whole swashplate, mostly on Elevator.
Setup is Standard for G 570, Gain on Swashplate is About 50.
Anyone some Idea or same Problem?
Greetings Christian
thestructured
Low headspeeds will require reduced cyclic gain and the best thing you can do is have a separate bank with this reduced gain for when you want to fly low headspeeds.
you can reduce Geometry 6° value little bit. This could help a lot. Ideally you can use a softer main blades, for example Edge FBL or similar.
cc1975
I have Rapid Blades, but with original SAB Blades or Zeal Blades i have the same effect. So reduce 6 Degrees geometry would be better like on 5,5 Degrees? lowering Swash gain would help also?
The 6 Degrees i have to set on the blade over the tail boom Right?
If i have 6 Degrees on the front blade i have 7,3 on the blade over the tail boom????
Greetings Christian
cc1975
I reduced Geometry from 6 to 5,5 Degrees and now the shaking is gone…..
will be also interesting for my upcoming Henseleit tdsf where i will have 800rpm lowest.
greetings christian
