Who explains to me how Hold on Geolink works
Pino74
Hi, can someone explain me the hold function on the Geolink how it works? In practice, the model stops immediately as soon as the sticks are left and maintains that position, but it is free to move again if I move the sticks, to then rest as soon as I leave the sticks again, or the hold function is understood as a block, ie the model stops and does not respond to the sticks, if you do not disable the l hold on the radio?
GeoLink Position Hold feature is working similarly as Coaxial stabilisation, except the model will maintain its horizontal position when sticks are released.
You can still change such position with sticks as with the Coaxial mode. Upon releasing the sticks it will maintain new position again.
Pino74
hello Thanks for the answer, it seems to understand that if there is a bit of pitch down, that is not self-leveled by the hold function, so the model tends to follow that direction, keeping only the horizontal stability. I hope I understood well
Yes, that is right.
For maintaining vertical position you can use the Altitude Hold feature.
Pino74
ok thanks
