Anti torque does not hold in reverse
passe partout
Hello, during fast walks back with my 450 trex, the anti torque does not hold the axis he picks up suddenly, what setting I have to do.
The gain seems good to me before it is stable and do not oscillations.
I speak in flight by not moving forward
Thank you
I am not sure if I understand correctly, but it is possible that you are talking about Fast forward flight and sudden elevator movement (usually up).
This is caused due to small Cyclic Ring and/or too high Collective Pitch. Please increase Aileron/Elevator Range in the Limits tab or decrease Collective Pitch range. Then all should be fine.
passe partout
Hi Thomas, in fast reverse, the anti couple picks up and the helicopter turns quickly.
I use a translator it's not easy; O))
Si qqun veut traduire:
Lors des marches arrières rapides l’anti-couple décroche violemment et l'hélicoptère fait un demi tour rapide pour se remettre dans l'axe de vol.
Merci
passe partout
The anti-torque does not hold in reverse it violently unhooks
Oh, I dont know what Anti-Torque is :-(
Can you explain in other words please?
Is it Aileron, Elevator, Rudder?
passe partout
rudder
Now I understand.
Please check Limits/Rudder End-points. It must be configured in the full extent, especially closer to the boom.
Next important thing is to set RPM high enough, because with a small headspeed rudder efficiency can be too low.
passe partout
ZeXx86 wrote:Now I understand.
Please check Limits/Rudder End-points. It must be configured in the full extent, especially closer to the boom. MAXI
Next important thing is to set RPM high enough, because with a small headspeed rudder efficiency can be too low. MAXI
passe partout
I think I have a better flight with the setting "Pirouette consistency" increased from 160 to 177.
Cdlt
