Connecting Spirit Pro and other telemetry Sensor with Y-Cabl
Posted: Tue 30. Jul 2019 18:31:58
by TDFun66
can i connect the Hott telemetry cable from the Spirit Pro together with the Kontronik TelMe Modul using an y-cable to the Graupner GR-16 reiceiver? Or is there a risk in damaging the Spirit Pro because both Signal cable are connected to the same PIN of the GR-16
I know there is a special Spirit telemetry cable V2 available in the shop for Jive Pro and Hott. But I already have the Kontronik TelMe modul installed.
Thanx
Re: Connecting Spirit Pro and other telemetry Sensor with Y-
Posted: Tue 30. Jul 2019 18:54:39
by TomasN
I am using Y cable for connecting Spirit and Unisens-E to Graupner receiver without problem. But devices must be set to emulate different sensors, e.g. one EAM and other GAM. And of course you can't connect plus wire to Spirit's SYS port. I use only signal wire to SYS port, because ground is already connected by other cable.
I assume that it should be same for Kosmik.
Posted: Wed 31. Jul 2019 6:53:34
by TDFun66
TomasN wrote:I am using Y cable for connecting Spirit and Unisens-E to Graupner receiver without problem. But devices must be set to emulate different sensors, e.g. one EAM and other GAM. And of course you can't connect plus wire to Spirit's SYS port. I use only signal wire to SYS port, because ground is already connected by other cable.
Thank you Tomas,
I was afraid of making a kind of short circuit between the two signals this way. But if you say it works, i will try.
