Rescue Action
Ktm250
I have a question on how rescue should work. Lets say my heli is flying forward and I hit my rescue button, should it stop that forward momentum and go upward? What I am seeing is that whatever direction the heli is flying it will do the rescue (like if i'm inverted it flips it over and then goes up) but it continues in the direction it was flying. So if I was going forward it will continue to move that way as it goes up. Is this normal?
Yes, this is normal.
If you want to stop the movement you can use Position Hold feature that is available with GeoLink module.
Ktm250
Ok Thank you. I have a Geolink but have not installed it yet. I will try the position hold when I do.
