Another Terrifying GeoLink Flight
Posted: Sat 17. Aug 2019 22:03:20
Hi Everyone,
I'm desperately looking for some help with issues I'm seeing with GeoLink. I've had a lot of problems which has lead to 2 crashes and 1 fly away.
Last weekend, I was flying my ALZRC 380. I engaged altitude limit and it appeared to work fine for most of the flight. Shortly after takeoff I tested RTH and it appeared to work fine as well. I flew around for a while and at one point, I lost orientation and engaged RTH again. Instead of flying back to the home position, it began flying away from me at a relatively high rate of speed. When I realized what was happening, I disengaged all GeoLink features and tried to turn it around, but it continued on flying away from me. I was never able to regain control and it flew off into the wild blue yonder never to be seen again. I searched on foot and from the car and never found it. By the way, I didn't get any RSSI alerts from the radio until the heli was well out of sight so I'm pretty confident that the heli was receiving my commands when I was trying to turn it around.
Today, I was flying my ALZRC 505. This time, I had both GeoFence (trying to avoid another fly away) and altitude limit engaged for most of the flight. For the first 5 minutes, everything worked as expected. Towards the end of the flight, I flew over my landing zone and engaged the auto landing feature. I also had disengaged altitude limit. Instead of landing, the heli began flying away from me as it also gained altitude. I released the auto landing feature to try and regain control. At this point I reengaged the altitude limit feature because the heli continued to gain altitude. It didn't help. I disengaged all GeoLink feature, but the heli continued to climb (I had the collective full down). According to the logs, the heli climbed to an altitude of over 500 feet. The only thing I could think of trying was to engage the throttle hold which I did. That worked and the heli cut power and began plummeting towards the ground. I disengaged the throttle hold and at the last minute the heli regained power and began to climb again. But the same thing happened. With all of the GeoLink features disabled, it began climbing, again with the collective full down. Again, the only thing I could do was engage the throttle hold, but this time, it didn't regain power in time and it hit hard skids down. Luckily, I had relatively minor damage. Again, no RSSI alerts during the entire flight.
I've been flying RC for over 40 years and flying heli's for over 15. While I'm by no means a great pilot, I do know how things work. All of the GeoLinks I own (4 of them... well, after last weekend, only 3 now
) were carefully calibrated while they were unmounted from the heli. I've mounted them as far away as possible from any sources of interference. I've checked and double checked the programing on the radio. Nothing seems to help. Everytime I fly with a GeoLink engaged, strange and sometimes terrifying things happen. At this point, I don't know what else I can try. Unfortunately, I've gotten to the point of giving up on them. I had such high hope for them, but they continue to disappoint.
I've attached the logs from today's flight. Obviously, I don't have the one from last weekend. There is an obvious GeoLink disconnect at 4:20. Unclear why this happened. The cable connecting the Spirit and GeoLink is perfect. I engaged the auto landing feature around the 5:00 mark. You can see the heli climbs rather rapidly to over 500 feet while all GeoLink features are disabled.
A couple of questions for everyone. It seems like the weak link in this setup might be the cable between the GeoLink and the Spirit. Would a more robust cable help? Something with shielding maybe? Also, I'm using the onboard governor. Is it possible that we're asking too much of the Spirit? Has anyone had any success moving the governor to the ESC?
Thanks for reading. Any ideas of what I can try, please let me know.
