Stabilization mode
Gadorey
First of all, I finally maidened with the spirit and really liked it. The bailout is working correctly and seems very nice. I am using banks as well, having at the moment Bank 0 as Stab Mode and Bank 1 as rescue.
However, a few questions on Stabilisation mode. How does Stabilisation limit the cyclic and/or rudder? I believe I read somewhere that cyclic is limited when in Stab mode, but reading through the manual I cannot find any description. Can I do loops, flips, rolls or fly inverted when in Stab mode? Is there a setting to increase max roll and pitch angles for this mode somewhere?
Or do I have to have a Bank with everything off in order to fly 3D?
Cheers
Rudder in the stabilisation mode works exactly as in case it is disabled.
Cyclic is working as with coaxial-like model there.
There are two parameters that you can change for this mode, so you can set behavior you like.
However, this mode is not intended to learn acrobatics manouvers, but rather basic model steering.
To get true practise, you can learn it in very normal mode with help of bailout else your experience could be mixed.
You can check the manual for all questions in Stabi tab section.
You can use this mode in inverted flight too.
