Spirit,GeoLink, mit Spektrum DX9 Sender
Börni1
Hello, I need help.
I sent the Spirit, - and the Geo-Link.
In addition, I bought the SPM 4649T.
As a remote control transmitter, the DX9.
Unfortunately, I now have big problems with the connections and setting up the switches.
When inserting the cables of the SPM4649T I prove the Rudd slot and
ELE / PIT / AIL Slot
Where, for example, will the cable of the Rudder servo and where the BEC power supply
plugged in?
I do not want to use slots as much as possible, because I use these for the functions
Geo link needed.
Can someone of you who also has the Spektrum DX9 as a sender, his assignment of the slots in the spirit and his switch settings with the Geo link?
Please help
Thank you Börni1
GeoLink should be connected at the satellite port.
SPM4649T at the AIL and RUD port according Spektrum integration guide - through Jeti integration cable.
ESC/throttle cable should be connected at the AUX1 port.
BEC cable can be connected at the AUX2 and/or CH0 port.
That is all you have to connect.
Börni1
Hello ZeXx86
Thanks for your quick reply.
I meant Spirit Pro.
How should the ESC cable still be connected to the RUD port? :?:
Börni1
I am sorry, this was mistake. Throttle cable should be connected always at the AUX1 port as described in our manual / Wiring section.
