YGE Telemetry & Futaba
Rooby
Hello
I try to get the telemetry working with may YGE 35LVT but without success.
It already worked with other devices. So in general it should work...
I have a Futaba T18SZ and SBUS receiver and µSprit connected. This is working well.
YGE and Spirit have latest firmware.
The programming port of the YGE is connected to the SAT of the µSprit (only GND and signal, no power).
On the YGE: I set to YGE telemetry, how about ESC BUS address setting ?
On Spirit: I set to YGE LVT/HVT telemetry.
On Futaba T18SZ : I set to Sensor 8 to "KONTRONIK ESC", how about the ID keep to 0?
Unfortunately I get no telemetry data. Can someone help?
do you use FrSky integration cable for transmitting the telemetry data?
Rooby
Yes thanks, you are right. In the meantime I found out that
for telemtry I have to replace the direct cable with the
FrSky integration cable to get it work. I thought it was not necessary since
the Spirit already worked with SBUS (but without telemetry).
