Spirit,AR 7700-SRXL / SUMD
Börni1
Hello, Spirit wants to work with the Spektrum ar 7700 receiver.
In the manual, the Spirit Pro receiver SRXL / SUMD
Because of the increased power consumption, it is recommended to use a dual-current cable.
It should be connected to the AUX interface.
Where should I take the power for the second line and is with the AUX interface
what in spirit meant? Thank
thanks
Börni 1
if your helicopter is 500 class or bigger then two BEC leads are recommended.
Usually ESCs are equipped with throttle + secondary BEC lead. So you can just plug both to the receiver. And then two leads can go to the unit.
Börni1
Hello ZeXx86.
Thank you for your prompt reply.
What I do not understand yet, they write: And then two wires can go to the device.
Do you mean two lines from the receiver to the spirit?
Or is the SRXL management enough for the spirit?
With best thanks
Börni 1
One cable should be enough if helicopter is 380 class or smaller.
Unfortunately I dont know any detail about your model.
