[ New Spirit 2 unit ]
We are proud to announce new Flybarless and Stabilisation unit!
It is called Spirit 2
The unit has completely redesigned internal hardware and brings the latest technology into the smallest possible footprint.
The biggest change is integration of 12-axis MEMS Sensor Fusion technology that will allow the most precise operation we can think about.
Moreover it allows to add more sophisticated algorithms to make all the features even better.
The unit has protection for All pins which mean it is not that easy to burn this thing even with a wrong wiring.
It has also more advanced Brown-Out protection to allow operation with a lower quality BECs.
Major change is that Spirit 2 has two Internally Separated Power Trains that allow very reliable functionality even in case of malfunction of a connected peripheral. For example in case of a short of connected Spektrum satellite/cable the unit will still work.
Support for GeoLink is built-in from the beginning with a safer data transmissation.
This unit is first Spirit ever with Right angle pin header. We aim to fulfill needs of our pilots while still keeping reliability at the highest stake. This was only possible with a single piece PCB and the right component.
Pins are also slightly thicker for better Servo connector holding force.
For both helicopters and aircrafts.
There are all features you know from other Spirit units and more are coming soon!
