Spirit Pro Mounting Tolerances on the axes to the Frame
Posted: Thu 24. Oct 2019 9:02:03
I know the unit has to be in perfect alignment to the Helis Frame / Main shaft on all Axes.
I plan to put it on a 3D printet mount where normally the Battery is located on a Trex 500.
So is there any tolerance in the angle or has it to be dead Spot to the Main shaft in all axes?
