No ESC telemetry, but I do get FrSky S-Port temelemtry
xoexoe
Spirit 2
R-XSR via SBUS
FrSky Horus X10S OpenTX 2.2.4 (I think)
Hobbywing 60A V4
I am unable to get any ESC telemetry data on my Horus X10S even after trying Discover New Sensors. But I do get telemetry of my FrSky S-Port mini voltage LiPo cell sensor so something seems to be working.
I also cannot get integration working. I have integration working with Lua on my other Spirit setups, so I know my TX is set up correctly for that.
Under Telemetry Settings in Spirit setup I have selected Hobbywing V4.
I have a direct connection from my HW 60A programming port to my Spirit 2’s SAT 1 port, but with the red power wire removed. I am not using a telemetry UNI cable. I’ve done this on Spirit 1 and uSpirit no problem (direct connection with red wire removed). I don’t think this is the issue because integration isn’t working either.
Also tried the SAT 2 port of the Spirit 2 but that didn’t work.
I have the FrSky integration cable between the SYS port of the Spirit 2 and the S-Port of my R-XSR. The longer side of the integration cable goes to the SYS port.
Any ideas on what to try next??
Find me on HeliFreak, username Xoexoe
xoexoe
Ugh Nevermind. Figured it out. User error.
My integration cable was not actually connected as I described it above. It was backward.
Great, thank you for the message!
