[SOLVED] Probleme mit der Telemetrie /SPM 4649T
Börni1
819/5000
Hello
I have problems with the integration menu.
It can not be switched on (Rudder stick on the right and Aleron on the left) and is not displayed in the remote control display.
There is also no indication of the receiver current in the telemetry data.
My hardware:
Remote control Spektrum IX12 Firmware: 2.00.80
Heli TREX 600
Receiver AR 7700
For telemetry SPM 4649T firmware: V1.1.10
Spirit Pro Firmware: 2.7.1
Spirit Geo Link
configration:
BEC to Spirit Aux 1
Second power supply from the controller to AR 7700
From the AR 7700 SRXL cable to Spirit Rudder entrance
1 Sat connected to AR 7700
Receiver telemetry SPM 4649T with Y-cable + and - on Rudder the orange cable
to AIL.
Did I do something wrong, please where is the mistake?
Best Regards
Börni1
yes, the AR7700 will not work together with SPM4649T receiver.
You have to choose which one you will use. But SPM4649T offer telemetry and integration support.
If using SPM4649T please select Spektrum DSM2/X receiver type.
Börni1
Hi
Does that mean that I can take the SPM 4649T alone as a receiver?
How then must the wiring be so that I can use the 12 channels of the IX12?
Greeting
Börni1
Yes. Please proceed according Spektrum integration diagram.
Börni1
Hi
Thank you very much, worked great.
