Yge telemetry
latjo-k
hi
the throttle % displayed in tx spektrum DX9 esc window says 49%,in tx throttle out i have 75%.
Iget the corect RPM setpoint in Spirit governor tab.
What can i do to correct the error?
first channel in your radio should correspond to travel at the Diagnostic tab for throttle.
Once it will match 0 - 100% it should be OK.
You have to use Travel Adjust feature in your radio to do this. Set linear throttle curve from 0 - 100% and try to match the end points.
latjo-k
yes i have check it,but i think there is some conflikt in pulselengdt.
in the yge 205 hvt you can set startpuls and span,and in the spirit start and end pulslengdt.
i begin whith esc increseing the pulslengdt antill the motor starts,and then setting span(the rpm dasent
increse anymore).
And then tranfer thus values to spirit,The rpm and governor works ok but the throttle value in tx esc window
shows 20% off.
in my tx the pulslengdt is 1 to 2048us for 0 to 100%.
//Lars
Were you configuring the Throttle range with Governor turned Off? This is very important.
By default YGE has very same Throttle channel signal range as Spirit.
So it is enough to use factory defaults for ESC and it will match the Spirit unit exactly.
Default range for Spirit is also 1100 - 1900us.
But you can also calibrate ESC (with Spirit Governor turned Off) and it should be perfect then.
latjo-k
the throttle and rpm works fine,its abaout the throttle value comimg from the esc telemetry,and shows up
in the transmitters Spektrum dx9:s esc window.
it seems hopeless to get it right the value is 30% below the reel throttle signal.
Med vänlig hälsning
//Lars
