Elevator nos up
latjo-k
Hi
In fast forward flight and i give some -cp to lover the altitud and,then give +cp to increse altitud again,the
helis tail goes down and nos up for a short time.More visible at higher RPM.Whitch parameter should i adjust
to eliminate this behavor?
//Lars
usually this is due to improper servo configuration or bad Center of Gravity.
To fix the problem please check this guide:
http://manual.spirit-system.com/index.p ... tive_Pitch
This should resolve all possible issues and improve flight performance.
Less commonly it is caused by different elevator servo travel but everything is described in the guide.
