Stabi - rescue duration
jjuk
Hey guys- It looks like "rescue duration" and all the settings under it are missing from the manual.
http://manual.spirit-system.com/index.p ... #STABI_TAB
Is this setting a time that the heli will "rescue and climb" before then using the "hover collective pitch %" to attempt to hover?
(e.g. the 3rd post here: http://spirit-system.com/phpBB3/viewtop ... =24&t=1125)
Thanks guys.
LogoX2
Yes you are correct.
Manual was updated.
Also you can find description always in the Spirit Settings when you hover mouse over a parameter.
jjuk
Does rescue duration include acro delay?
Or is it additive?
E.g. acro delay + rescue duration = time until it hovers?
Or
Rescue duration = time until it hovers?
If the 2nd is true, then it is impossible to have rescue duration less than acro delay.
