swashplate moving in wrong direction
Posted: Sun 26. Jan 2020 3:48:08
I have set up my spirit 2 system for the first time on my trex 600. Everything is moving correctly except the swashplate. When I tilt heli to the left or right, the swash plate does not move correct direction. What setting do I need to change to make it move correctly?
This is the second spirit 2 system that I have set up. The first one I set up on a trex 550e. And I had no issues. The only difference is that on the 600 the system is mounted in the front with the servo wire inputs are facing forward. I set it up forward on the computer set up also. So I'm not sure why the swash is moving the wrong direction.
