Rudder help
Badger1666
After setting up spirit2 on a jumper t16
I have a issue, after powering up the rudder slowly goes full travel in one direction and stays there, I can move stick and rudder will move, but will always creep back to full travel on one direction.
What can cause this?
Trek nut
Hi ! Did you disable your rudder trim ?
please check Diagnostic tab and verify that Rudder channel is at 0% when sticks are centered.
Badger1666
Hi
I bind the receiver again and all seems to work on the bench.
