Binding with Spektrum DSMX satellite AND telemetry receiver
Fortune7
For simplicity on a new setup, I configured the Spirit2 with satellite only, then later added the telemetry receiver and did the bind process which brought telemetry. Both satellite and telemetry Rx have steady LEDs. On subsequent switch -on, telemetry is not present. I am using the correct (JETI) cable.
Should both satellite and telemetry Rx be bound TOGETHER, needing a bind plug at ELE-PIT-AIL port (dsmx config) AND a bind plug in the SPM4649T harness?
Thanks, Andy
UK
Sent from my SM-T710 using Tapatalk
binding should not be an issue.
Please try to connect satellite to a different port if free.
Is your radio DX9? Do you have the latest firmware in the Spirit unit?
Fortune7
Hi Tomas,
Thanks for the quick reply. I will try the satellite in the other port, but to clarify, with the telemetry Rx also connected, does it need to be also bound (again) and if so after, at the same time, or not at all?
My Tx is Spektrum iX12 - the bind facility works without a separate switch-on-with-bind-then switch off.
Maybe if both receivers have the steady LED they are bound correctly and my telemetry problem is something else? I will keep looking.
Thanks, Andy
You are welcome!
Both LEDs should be steady on at the receivers but it does not matter when they are bound.
