Stabi Rescue
Posted: Thu 13. Feb 2020 15:44:02
by latjo-k
HI
Ihave a spektrum dx9 and i use channel 8 and switch A to activate stabi rescue.I also use bankswitching
from F-mode switch ch 7,and i have set it up like this.Bank0 stabi normal for takeoff and landing,bank1 rescue normal,bank2 rescue normal.
The problem is that i forgot after takeoff to deactivate switch A,and Changes F-mode to 1(bank1)and the heli
starts to climb higher and higher until i manages to switch off switch a and go into normal flight.
Is there a possibility to prevent this happens if i forgot to switch off sw A after takeoff in the TX or in the unit?
//Lars
Re: Stabi Rescue
Posted: Fri 14. Feb 2020 15:12:56
possibly you can program Alarm in your radio so that it will not turn on if you will forget to set switch in a wrong position.
Anyway preflight control is always highly recommended. At least to check if everything is moving properly.
Re: Stabi Rescue
Posted: Fri 14. Feb 2020 17:16:53
by jjuk
@ZeXx86 Please add software so stabi is on a SWITCH not a bank.
Banks should not be required to switch between different stabi modes.
A switch for stabilisation/rescue/normal would be much better than messing with banks, imho.
Re: Stabi Rescue
Posted: Sat 15. Feb 2020 11:27:40
by latjo-k
Hi again
I removed stabi from bank0,insted i have lover the rotation speed on both cyclik and rudder,and add some
expo in tx.
Then i only have to use sw A for rescue bank 1 2,and put swA on check Before flight.
Hopfully i dont need to use swA at all,
Thank you all
//Lars
Re: Stabi Rescue
Posted: Mon 17. Feb 2020 14:39:00
by martisek101
jjuk wrote:@ZeXx86 Please add software so stabi is on a SWITCH not a bank.
I think the same. Its really uncomfortable with banks...even more because switching banks have delay...I totaly dont understand why.
We should be able to use stabilisation and rescue in the same time too...if everything was possible to assign to a switch we could easily set everything in radio as we like and as we want.
Re: Stabi Rescue
Posted: Tue 18. Feb 2020 22:40:29
There is zero delay between bank switching.
Possibly only delay might be visible when Spirit Settings is opened. But during flight it is always instant change.
Yes, we are working on switching modes without banks.
Re: Stabi Rescue
Posted: Wed 19. Feb 2020 10:57:10
by jjuk
Fantastic.
Re: Stabi Rescue
Posted: Wed 19. Feb 2020 13:42:26
by latjo-k
ZeXx86 wrote:There is zero delay between bank switching.
Fantastic,Thanks Tomas
Re: Stabi Rescue
Posted: Wed 19. Feb 2020 16:02:04
by martisek101
ZeXx86 wrote:Yes, we are working on switching modes without banks.
Glad to hear that.
OK I observed the problem only in settings but I then was afraid about using it in flight. (I wanted to make rescue possible in all modes even when stabilisation is active...by switch witch would activate stabi function and switch to bank with rescue at the same time...but the delay would be a problem)
So there is one improvised solution if there isnt delay...
