Spirit setting windows 10 closing
jjuk
I'm using 2.8.0.
When I'm in a popup dialog such as diagnostic or geo settings for a long time, when I close the dialog the main window has disconnected from the spirit unit and I lose my unsaved changes.
I'm using spirit red and usb.
Seems like a bug.
could you send a Flight log from your Spirit unit, please?
Is there a Backup oscillator event?
jjuk
It's not during flight. It's when configuring the unit on the bench, connected to a pc via usb cable.
Yes, I understand, but Spirit unit is recording logs also during configuration.
There we can see if something is wrong.
It must work in the same way even 2 days later if connected all the time.
It is not happening at any of our testing computers so I guess it is rather not a bug.
jjuk
OK, i'll grab the logs for you later tonight. Thanks for your help.
jjuk
The log file is attached. It is clean.
Go to General->Channels, and wait. The device disconnects after a random period of time.
I have tried this on 2 different spirit red's, both are running v2.8.0.
I have tried 2 different USB dongles.
I get the same results with both; random disconnect.
I can try a different computer on the weekend, but please try this on your system.
My Spirit2 will be here tomorrow (hopefully), i'll try that too.
spirit-log-2020-02-17-205345.pdf
(64.59 KiB) Downloaded 48 times
