Geolink Vertical Gain - Lower Limit 50
enied
I have the GeoLink on a Diabolo 700 Heli currently. Everything is working fine but I still have a ping - pong like behavior with altitude hold. I set the vertical gain already to 50, it is better but still there. Is it possible that I need to set the gain even lower than 50 ? 50 is the lowest value I can configure in the PC Software. If possible, I would like to try with 40 to see how it behaves. Any chance for such a test ?
Best Regards,
Eugen
enied
Tomas, could you reply, please ?
Best Regards,
Eugen
we can prepare firmware with lower vertical gain limit.
Until now it was not needed but it is easy for us to increase the range just for try.
I have sent you PM with links for download.
enied
Hi Tomas,
thank you very much for your support. I have downloaded the PC Software as well as the Firmware and installed / updated everythig. It worked flawless and I could set the Vertical Limit to 40 now. It could take a few days to test this setting and I will report back about the results.
Best Regards,
Eugen
You are welcome. Thank you for informing us.
