Does anyone know if there is any available software to run a full systems check / diagnostics check on a Spirit Pro ?
I am having some strange behaviour in that setting up a new heli (With an Spirit Pro that was involved in a crash)
Everything appears fine, bind my SAT, get everything dialled in via wizard or manually, then it appears when setting up Rescue mode - I lose all control between Tx and SAT (If I add in a Main Rx - everything is fine, but I lose the SAT connection) - Power off and on does not correct the lost connection...(even re-binding SAT does no work - Lights go from flashing to solid and Tx says successful - but nothing works in reality)
Would be nice if I could run some kind of diagnostics on the unit to confirm all is operating correctly to eliminate a systems fault - then it would mean the fault must be with me
Thanks in advance
