Telemetry problems
shoveopoly
Hi all. New guy in need of a little help. I have a Spirit Pro and Hobbywing 60a platinum V4 hooked to a RXSR receiver sending telemetry to my Taranis X9D. I get all sensors showing up, but RB1V shows 0. Well aware RB1A and RB1C will stay at 0, because 60a doesn't have the output for it. Thanks for reading.
do you see at least some value from hobbywing telemetry?
For example RPM?
If not, then problem is possibly in the old HobbyWing ESC firmware.
shoveopoly
I see RPM, FUEL, tmp1, 5120, and RB2C. RB1A and RB1C are zero, as expected with the 60a. Just not sure why RB1V is also zero. Might it be because only bench testing with no blades?
you should really see RB1V value from the beginning.
Maybe your motor is disconnected. This would explain the problem.
