Cannot Setup the Spirit2
jamachine
Hello first off what it is on dx9,spm4651t,hitec hs65mg,tail futaba9650 trx450 horizontal 180 servo plugs toward the front on tailboom mount
now the fun part throttle stick up all three servos go up with a little wobble at the top from aileron servo it also has that same little hesitation or wobble then too, now the other stick is really strange when moving the aileron it acts more like the elevator both pitch and aileron move the same direction at the same time the elevator moves the way it should,seams maybe a little weak,so when you move the elevator it of course move more like a aileron
Thanks Stan
morrchew
It’s not set up as per manual , you also my have to servo reverse a servo in the FBL
it is possible your radio has CCPM 120 mixing enabled.
Please turn mixing in the radio and set it to H1 90° / no mixing.
