Loosing telemetry on OpenTx
azaz44
Hi Thomas. I have the following issue. If I run any OpenTX LUA script for Spirit (for example basic.lua), then after exiting the script I don't get ESC telemetry values anymore. All numbers become red and they are not updated anymore until I restart the spirit. This is true even if I didn't change anything in the settings through the script and didn't not click "Save settings". I think I didn't have this issue before. It makes adjustments complicated..
Additionally I have to force quitting the script by long pressing RET key (on Horus X10). I think it was different before.
Is it something known, or is it some problem with my system?
I have updated many things at once - Spirit to 2.8, OpenTx from 2.2 to 2.3.7, ACCST to v2, and changed to a different receiver. so I have no idea what the reason could be. Unit is Spirit Pro (Silver / grey).
at side of Spirit units nothing changed in the integration. It should be very same, including Lua script exiting. So the changes are due to update of OpenTX.
When exiting the Lua script, the Status LED should be steady on. During configuration it should be flashing.
If it is flashing even after closing then this is reason why telemetry values are not shown. During configuration telemetry values are not updated.
azaz44
Hi Thomas. Yes, this is a problem with OpenTX on Horus radios. I hope they fix it soon.
https://github.com/opentx/opentx/issues/7033
