Bank switching - which value to send via 3-way switch
Posted: Sun 14. Dec 2014 15:10:57
I did some search in the forums, but did not get a clear answer, it is probably very easy.
I want to switch banks via a 3-way switch (mix0,1,2) on Devo 12. Now, which value do I have to send via channel 5 (I am using RX801 Devo 8 channel receiver) to the RX to trigger bank 0, 1, 2?
I understand that I am not actually sending any value that is used within the Spirit, but depending on which bank I activate, the Spirit uses all the configuration connected to that bank.
So, I need to tell my devo 12s (running deviation freeware) the value it should send on switch position mix0, 1,2 .
Thanks,
Michael
Thanks,
Michael
